Water pump solution!
For everyone out there who has tried everything finding a water pump leak or air bubble or broken pressure valve or any other thing that you’ve tried when your water pump runs every 30 seconds or sporadically. I can tell you my solution in my case after checking absolutely everythingand even replacing the water pump. I’ve discovered that if you turn. The outside water valve to “city water“ even though you’re not on city water, it stopped the problem. This must be due to an air leak getting into the system from the tank fill side anyway I hope this saves someone else three weeks of hassle that I went through.
Thank You for sharing.
How old is your system? In my '22 Ambition, the valve HAS to stay in city. If you put it in fill with the water pump running, it just circulates water around the pump and it never turns off.
