Water coming out vents and light fixtures
I have a 2023 ambition when using our ac in the kitchen area water started coming out the two vents closest to living area and also started coming out light fixtures above sink anyone have any ideas
This is usually due to a plugged weep hole / drain pan on your AC unit. Water can’t escape and be ejected to the roof and flows into the unit. The weep holes get plugged with leftover material during production.
I took off my AC covers and drilled my weep holes a bit larger than what they were. I also cleaned out all of the leftover sawdust.
Some condensation is normal on the metal returns but coming out of the lights is not right.
Hi clydeh
Agree with RyanB about the drain holes could be clogged, we had the same thing happen with ours and found out the coils needed cleaning and the little foam insert they sit on was all clogged up and also needed cleaning, after cleaning no more further problems
