Slide lubricant for the mechanics
Good day all I wanted to ask the community what you all use to lubricate the larger slides kitchen and dining area and which parts you lubricate.
I’ve been using silicone spray and wanted to confirm this is t
You will want a dry lubricant, this prevents dirt and grime from building up on your gears. I am not a brand snob, so any quality dry lube spray.
Thanks I’ll keep using the below then switch to a dry lube
When I asked the techs about it the absolutely said dry lube and not to use silicone… FWIW. Personally use Boshield T9 as I’ve been using it for years on boats.
Thanks I’ll switch to the dry line suggested
