Having trouble drawing sanitizing solution into tank. My unit has the 8 position Anderson valve. I follow instructions with left valve on tank fill and right valve on sanitize. I turn pump on and it doesn’t draw. I can turn left knob to winterize and right to normal or bypass and it draws with pump on but probably not going to tank.
When I sanitize and want to include the fresh water tank, I’ll place the sanitizing agent in the hose and then use the standard tank power fill positions. That directs the sanitizing solution into the fresh tank and you can distribute the water from the tank to the interior lines using the on board pump.
I’ve used this setup for including the fresh tank.
CITY FILL TANK – TO FILL STORAGE TANK FROM PRESSURIZED CITY WATER
Here’s a couple of diagrams that might help decode the valve positions (the labels are slightly different than Vanleigh used, but the positions are the same).:
SANITIZE /WINTERIZE- TO SANITIZE/ WINTERIZE FIXTURE (NOT TANK) FROM UNPRESSURIZED SOURCE
I used the diagram with valves set on Sanitize and Winterize and it drew the solution just like it was supposed to. I had previously tried the Beacon settings according to the manual and could not get it to work. Not sure if they have a mis-print or I just wasn’t smart enough.
Anyway we got it working. Thank you for your assistance.
