Multiple problems with my 5th wheel, has anyone else had as many problems as I have? I did not realize that vanleugh was going out of business when I bought this POS! I’m getting ready to be in a huge battle with LA MESA RV. Any help on what problems you are having would be great. Is anybody else in a legal battle? Thanks for input. I have never posted on a forum before not sure if it works or not?
We have a 2020 Beacon 39FBB, although not problem free (it is an RV
) , we’ve found it is better than others we’ve owned. Any problems I encountered were handled directly with Vanleigh under warranty, and I repaired them myself or had the Tishomingo Service Center do the work and avoided the dealership as they were a source of the problems IMO.
It was disappointing to hear about Vanleigh shutting down, but Tiffin still honors the warranty and I’ve been able to get parts through them.
What sort of issues are you encountering? What’s the model year you have (is it still under warranty)? Have you contacted Tiffin/Vanleigh about the issues?
The Tishomingo Service Center was used as a warranty service provider for Vanleigh and I had good experiences using them. There are probably other good RV service centers available outside of the typical dealer ones.
We purchased our 41FLB Vanleigh Beacon 1 year old in September 2021 mfg date September 2020.
First owner bought at Lazydays Tampa, spent winter in it, drove to Lazy Days in Mesa AZ & traded in on Class A!
Since I wasn’t first owner I took out service insurance policy with AWG.
Prior to taking possession 2 of the 3 heat pumps failed so Lazydays replaced with 2 Furrion FACR14SA-BL air conditioners. 14.5 BTU rooftop air conditioners at their cost. Heat pumps were unavailable due to supply chain issues!
Our issues have mostly been Lippert related. After struggling with front jacks on level up 6 point dropping under pressure they ( Lippert) replaced the entire hydraulics including. See other post in forum.
Lately Front living room slides failed - see post in forum. A design flaw by VanLeigh because there are no flor roller supports under the heavy sleeper sofas, on bumpy roads all flopping stress is in the wall “ H” frames.
Frame flex repair near front cap. See other post in forum.
These units take a real beating on US Roads with I-39 from Rockford to Bloomington IL among the worst!
If you want to see a total lemon by VanLeigh Beacon watch the YouTube Videos “ midlifedetour”, those poor folks had every failure imaginable. They have a website as well - midlifedetour.us
We still like our 41FLB which is our second 5th wheel- 1st was a used 2012 Landmark Mesa we bought in 2015.
Hi regarding your Beacon is one of the problems with the frame? What are the biggest problems with it?
We had a frame separation at the front cap area. Had it reinforced at Robert Crist RV in Mesa AZ.
The main frame has not provided any problems.
The folks that had massive problems with their Beacon posted a series of YouTube videos - search for Midlife Detour to view.
Oh wow! My thoughts exactly on this 2023 Ambition. We have had and are having more issues then i have time to write in one post. I am literally in tears because the workmanship is so bad. Both of our outer doors are bowed and we can’t shut them without really slamming them or pushing them shut from the outside. Both doors kept coming open as we were traveling. Our awnings kept coming out about 2-3 feet while going down the road. Almost all the screws in the metal trim around the bottom of garage have backed out, as have the ones on the stairs. On the happy jack, almost all the screws have come out of the bunk. The dimmers on the light panels stopped working, to dim we have to use the master spyder panel. On the outside if the galley slide the outer skin is separating and there is approx a 5 inch long (not wide) gap.we still cannot get our generator to work. The aqua-hot was broken and we had to pay an RV repairman to replace the broken switch. The ceiling above island which has the lights and the a/v vents and intakes was not put on straight, and it is starting to sag, so the cupboard door rubs on it, which means we cannot open the door all the way.
The heat in the l/r and the garage do not come on unless we turn the bedroom heat to 72°, and it is still cold in both rooms, while cooking in the bedroom. We have had errant water puddles just hapopen on the bedroom floor and in the kitchen, with no clue where it comes from. The glue on the 1/2 bath in garage let go and the wall panel is bowed way out beyond where it is taped. The cabinets are beginning to sag.
There are many more issues that we should not be having on a brand new unit. This was the first trip we have taken in it, and sadly the last as we are looking to trade it in on a better made unit. But no more Tiffin products for us.
So sorry to hear-takes the fun out of RVing!
Since we had Front living room Schwintek slides on both sides repaired I put plastic leveling bolocks under each-gotta remember to remove before extending. Seems to be a good work around for a bad design. Should have support rollers under each like present under bed in rear bedroom.
We also broke a leaf spring in MN & driver side rear tire wore down to steel belt! This was a Friday at noon. The gang at Hilltop RV 2 exits north of Rochester, MN ordered new 8k leaf springs for each side of rear axel which arrived Monday morning & they had us back on road by 2:30!
Spent weekend across the road at Tilly’s RV park (self serve).
Made it back to AZ with no more problems.
I’ve always wondered why the screws on all the trim work themselves out-why can’t they tighten?
I am always amazed when we set up at the end of the day that anything works! I’d like the US Secretary of Transportation, and each State DOT Chief ride a day or 2 with us to see the status of our Interstate & US road system is in.
I’ve mention in other post to avoid I-39 from Rockford to Bloomington at all costs!!!
Tip on air conditioner/heat pumps.
Always check the water cup where condensation collects prior to flowing out onto the roof then to one of the corner spouts. Just had to clean the weep holes inthat cup due to debris plugging weep holes from cottonwood cotton & bugs.
It caused water to enter the cold air duct & drip on floor between bed & dresser. Of course we also had lots of rain here in Minnesota to add to the issues!
That’s a good tip. Those weep holes do get clogged.
I made mine a bit larger when I first picked up the Beacon from the dealer.
