My 2021 Beacon 41FLB developed front jacks creep when traveling-yikes.
Many calls to Lippert to do test to diagnose issue. End of June 2022 at Sheridan Wyo they checked hex screws on top of jacks & inside generator bay ( I don’t have a generator).
On to Cheyanne all ok, then to Colorado, but in Wilcox AZ had difficulty getting jacks up to hook up. Used a pry bar to get up when touchpad buttons held. Then strapped front jacks up.
Took to RV shop, they worked with Lippert & replaced all valv cartridges . Worked fine on trip to Rose
Parade in Pasadena.
Then May 11 we ok’d up to head to MN. As I was doing final check front master jack on passenger side. Took toRobert Crist RV in Mesa. George, service mgr, worked with Lippert & replaced master jack, master jack valve cartridge, Deutschmark solenoid on master jack.
Using boat trailer safety chains under each front jack as insurance! 1st day fine. Second day creep on master jack to tightened against safety chain but not under pressure.
I called Lippert tech & he suggested unplugging the two wire plug on top of master jack. That worked for 2 days (still use safety chains for insurance). Then 3rd day the creep returned on master jack but did not tighten against the chain.
Am in Mankato working with RVTAA certified rv technician with diagnostic test kit.
I’ll report results soon I hope!
