Kitchen faucet the head of sprayer leaks
I have a 2021 Vanleigh Vino how do I change the kitchen faucet?
Same way you change the kitchen faucet in a house and you should be able to use a standard one hole kitchen faucet instead of having to buy a RV replacement unit.
Turn off water supply under sink
disconnect hot water and cold water supply lines
remove faucet nut holding it to the counter (this is the hard part)
remove faucet
Install is the reverse steps of removal
As Steamboat noted the nut holding the faucet to the counter is the challenging part, use whatever will get the nut loose.
Never quit never surrender. Good Luck.
