Need assistance on how to access back of living room TV on 2016 325RL.
Hi Jeffmllr - If Vanleigh used the same TV mount on the 2016 models as they did on the 2020 models, you should be able to see the mount and the screws holding it to the wall. On ours I believe there were 4 or 5 along the top of the mount somewhat hidden behind the soundbar.
You should be able to squeeze behind that soundbar and remove those screws. Then the whole mount structure can be removed with the TV and soundbar attached.
I removed the installed basic TV and installed a standard wall mount (there are thick wood strips behind the wall) that extends, tilts and swivels along with a better quality Samsung 55" TV.
Blue arrow shows the approximate location of the screws points for the TV/soundbar mount.
Thank you for the response. I’ll definitely check it out.
