I have a 2018 Vilano 369fb. I am new to great park that provides cable and internet along with electricity. I think I may have to drill a small hole to push my ethernet cable through. I don’t think there is a dedicated port like there is for cable. Where would be an ideal place to drill the hole or is there a place ready-made that I am unaware of? Thanks for all your help, everyone.
Sincerely,
Tom
Hey Tomcat - we have the same model in the Beacon. Personally I’d try to avoid drilling a hole to pass an ethernet cable. A couple of options to consider would be to slip the cable under the slide seal since that’s probably the easiest path. I use Starlink and pass the cable through the existing holes in the bottom of the kitchen slide behind the fireplace. I then run it up behind the TV to the cabinet where the radio and power outlets are so I can plug in the Starlink router.. You can access that area by removing one of both of the drawers above the fireplace.
Thank you so much for your help. You were absolutely correct. I got under the galley slide out and was able to push the Ethernet cable through into the living room from the back corner so I could run it behind the furniture easily enough. I hope you have a wonderful day.
Sincerely,
Tomcat
