I have a Vilano 390LK and the dishwasher started to leak. I turned off the breaker. Done. Now I want to remove it. Any experience with this issue.
Hi Dave- We have the Fisher Paykel dishwasher in our 2020 Beacon 39FBB. I’ve had to repair it for a water leak and bad controller.
Assuming you have the same model of drawer we have (DD24SI9). The water shutoff on ours is in the kitchen island under the sink. Is the leak coming from the water source or is the unit itself leaking? That might indicate a bad seal around drawer or a bad drain line.
You can remove the front panel and the dish drawer to check for leaks. Don’t think I can upload the manual, but the screenshots below show how to remove the front panel and the drawer.
Other than the one leak (broken shutoff valve) and the controller, the dishwasher has worked quite well.
Hope this information helps.
