Hi there
Anyone know the clearance height of a Pinecrest 2020 Vanleigh Pinecrest 392MBP
I have the height as 12.5 wasn’t sure if included the ac units thanks all
Hi there
Probably between 12’6” and 13’ I think. To remove any doubt when approaching low clearances I’d suggest measuring it on level ground yourself from the top of the AC units both front and back.
Our Beacon was about 12’7” but is now at an even 13’ (front to back) after the MORryde IS install. It’s good to know the correct height in case you get into any tight situations IMO.
Thanks Stuart I’ll take 13 or 14 ft just to be safe
