Stuart
March 3, 2024, 1:51pm
4
That model might be a little different. I think there was an earlier thread about that style toilet here and I found a manual for that model that might be helpful to you.
I think saw from a previous post you mentioned you had the 41LKB floor plan which has two toilets, similar to our floor plan.
I’m guessing this toilet is the one located up front and should be a macerator style since it’s not located directly over the blank tank. Ours is a Tecma model and has a similar indicator on the flush button panel using green, yellow and red roughly corresponding to less than 1/2, more than 1/2 and then full. On the Tecma model, when the indicator is red (full) it will p…
