Another Tip you may want to consider
I have occasionally been inside the electrical panel and the sub panel & I have noticed the ground & neutral buss bars have unused slots. Well I opened the sub panel one day to find loose screws rolling around inside the panel. So make sure they are tight even if unused. With the power off of course or the power plug disconnected from park power pedestal. While you’re in the panel make sure all screws are tightened.
Good tip Ralph! I’ve made a habit of checking everything for missing/loose screws as I don’t want any getting caught under the slides, or like you mentioned in the breaker panel, possibly shorting something out or worse.
Excellent tips. May I add, a drop of Locktite Blue helps. Power off and do one at a time.
