Any quality suggestions for replacing the accent strip lights? I like having them, but after 2+ years of near continuous use they are starting to burn out.
If your talking about the under counter (and other locations) strip LED lights, you can buy them at most home building stores or on-line. There is a junction device that is used to add or replace lengths of the lights or damaged sections. Google is your friend with youtubes on the repairs and lots of information on how to buy and install them. Mine are only 1 or 2 colors (system only uses 1 color but there are several diodes on the strip) and I think the more popular ones now can do more colors (more diodes on the strip). Hope this helps and doesn’t lead you down the incorrect path. I will look for examples and post when I find them.
Thank You Steamboat.
Here is one web site that has LED strip lights
or just do a Google search for LED strip lighting for a lot more options.
And here is a link to the LED light strip connectors.
On my 2019 Vilano 370 GB, the galley light strip runs under the cabinets and microwave but the powered end is inside the refrigerator enclosure so to replace the whole string, the refrig has to come out. I will just splice a new LED strip light section at a point that is convenient. While looking at the strip light on the web link, you will see 4 dots (yellow?) every so often and that is a point to end or start a light strip.
Hope this helps a little bit.
Very helpful Steamboat! Thank You!
I just replaced mine in the front living room above the couches on both slide outs plus accent strip over the dinette and over the refrigerator. I just spliced in the wires. My old strip lighting was more “yellow” & new ones are bright white! Ordered from Amazon.
Mine are only 1 color. I’m surprised how warm they get.
Not hard but just helped to have an extra pair of hands.
