2022 320gk Hydraulic leak on dinette slide- sharing info
While camping labor day weekend I noticed red atf fluid seeping from the underbelly on the dinette side, under the slide primarily. Yesterday I started popping the underbelly nails out along the camp side. I have a 2ft long pry bar with a curved end that has a nail puller V in it. I hammered that curved in under the coroplast right behind the nail washer and they popped right out. I removed some screws in the middle and the forward aluminum retaining bar. I was able to drop the material down enough to drain the ATF fluid and access the rams under the slides.
Having the mira module and app came in handy. I ran the slides out and in 3 times while sitting under the rig looking for the leak. I couldnt locate it. So my redneck ingenuity kicked in and I decided to hold the button down and let the system build a lot of pressure. Sure enough the fluid started spraying like a scared skunk. I disconnected the line at the ram and at he valve block in the front compartment. I taped a 14 gauge electric wire to the old line and pulled it through with the old line so I can pull the new line back in all the way to the front compartment. It was the black retract line that goes from the pump valve block all the way to the dinette side slide ram. The installer ran the hose through a metal frame at the rear side of the rams and the hose looped back to face the front of rv and went through another hole in the same bracket and connected to the outboard end of the dinette side ram. The hose rubbed on the metal and cut enough to start seeping when it would run in and out. Its probably leaked awhile before I noticed.
Went today and had a new hose made. Went with 5800psi rubber / wire braided hose and added a cut protector. $112.50 out the door.
Good job tracking down the source of the leaking fluid. Curious where you had the new hose made. I had my underbelly off earlier this year for some tank work and didn’t see any hose leaks. Will keep this in mind in case I see any leaking fluid like you described.
Shawn I am curious as to which holes in the crossmembers on the frame they routed your hydraulic lines. I was worried about chaffing and asked the question during the construction of our unit and they told me they route them through the smooth channel in the crossmember so there is not a problem. I was still concerned about the lines resting on the crossmember or bouncing around during operation. This is our frame and the hydraulic lines ran through the section the normally do - I am wondering if they routed yours through those channels or went through one of the smaller holes. I had to replace two hydraulic lines on my rig this last summer and had them made at MCFP (Motion Control Flow Products) and did the same as you had them wrapped with the protector. I had a few lines “spraying like a scared skunk” however mine were from blistering and not rubbing. I replaced a few sections of pex under the Beacon for chaffing through on the frame however.
@Stuart J&F industrial in indianapolis made the line. Its standard 1/4” line with #4 jic fittings any hyd shop can make one.
@RyanB Great photo. The red line represents where they ran it. The yellow is where it rubbed. My guess is it rubbed on the back edge because it looped back around On yours they looped it on the inside you can see it resting against the frame that mine went through. I will see what i can do to reroute it if i cant it has the rub guard
Installed the new hose. I forgot I had the guy add 10" to the hose. With the cut guard it is fully protected even when ran back as it was. After install I ran the slides in and out several times. I then dead headed the pump until it internally by-passed a couple of times, to ensure there were no more leaks. All was good and we buttoned up the underbelly, I installed short self tappers with new fender washers where the nails were with the exception of two above axle hanger due to it was easier to just hammer the nails back in compared to trying to get the screw gun into the area.
Now on to bearings hubs and break inspection on RV and Tune up on the chevy.
The bearing repack went well. We adjusted the brakes replaced the seals and repacked.
The truck tune up was another story… The 6.0 vortech gas engine tune up consisted of plugs wires and coil packs. My labor was free, I had about $850 in parts most of which were the new coils. The plug wires can be a bear to click onto the plug and coils. She’s running good now. Hopefully I gain some MPG back. #4 and #6 plugs were really bad.
