Leak over front axle 2021 39GBB
I have a leak right above front axle on my Beacon 2021 39GBB, I haven’t opened the underbelly cover to see, just wondering if anyone knows what is in the general area of that front axle, possibly grey tank overflow? After smelling and tasting water it is fresh water, I did just fill fresh water tank, I have move over to city water to see if it is coming from pressurized side.
I had a a similar leak in my 21 34RLB and was the pex line going to the sink in the island. It had rubbed against the frame and wore a hole through it. Your fresh tank is above the axles and on that model the two grays are more forward and do not have an over flow.
This is the best pic I can find on my phone of the area. You can see the fresh tank to the left there over the axles and the line coming up from the frame to the island. Mine had chaffed as it fed through the frame crossmembers.
Thank you for the pic I am gonna get under there tomorrow and hopefully it is something I can fix in short order
Did U find your problem? Hopefully so. I’d pull the panel inside the storage bay using a Phillips head screwdriver. I’d look behind where hook up water hose and see if you see any water leaking from there.
I don’t know if this is pertinent or not, but I also have a 39GBB. Mine is a 2023, but the PT valve on the water heater releases water that drains down the side, leaving a puddle of water. Is the leak that you were finding located there? If not, I agree with another user that you can crawl in behind the pass through storage wall and see if you can see anything there. Pulling that underbelly down is a big job and would be the last thing I’d want to do.
